- Thu Jun 09, 2016 12:07 pm
#6355
On my 1999 500 Bullet I'm changing the mini-indicators for the proper-sized Minda home market ones. First to swap was the LH front, and all is fine. Then I swapped the RH front and the indicator works when the wires are connected but the indicator is not bolted up. When I bolted it to the bracket on the shroud it stopped working (the LH one is still OK). I unbolted it to check, and it worked again but doesn't work when bolted to the frame. It's as though the electrickery is leaking into the frame and not completing the circuit.
Apologies for my electrical ignorance, but does anyone have any suggestions? Thanks, Mark.
