- Wed Aug 08, 2012 9:34 pm
#962
OK,
So in my previous post I said B****rd the bullet!
Sooo, it may be more a case of dozy b****rd the owner, remember I said the oil level was low?, now I assumed this was as a result of the aforementioned loss of compression and stuttering, and the odd little 'hmm, that doesn't sound right' noise prior to stopping should have rung some old dusty bells from my 2 stroke days!
Stripped the top end after trying everything I could whilst in place to see if the prob was there, all OK, head gasket, OK, bit of a hot spot exhaust side but no blow past it seems.
(It all came apart a lot easier this time BTW, lack of super sticky black ATV silicone would do that)
Barrel off and this was what I saw.
Pic 1 piston rear:-
Pic 2 piston front:-
Pic 3 barrel rear:-
Pic 4 barrel front:-
So, as you can see I had a partial seizure, the top two rings, (which weren't aligned, been easier if they had been), have welded themselves into the rear of the piston groove, the oil control ring is still free in it's groove.
The rear of the barrel is badly scored and the front has a couple of new score marks clearly where it had started heating up, all this most likely due to oil starvation.
While it was pumping through quite vigourously when kicked over on the kickstarter into the sump and onwards from the sump to the head the fact that I was only reading just above the L mark on the dipstick indicates the small amount in there simply couldn't keep up with oiling the bore.
I've been mentally kicking myself up the arse as I am solely to blame for not checking the oil frequently, especially when I know it was just over 1/2 last time I checked prior to going for MOT, being used to more modern machines for a while that use little if any oil and have a sight glass hasn't helped me remember either.
Some pics of the sump area and (hopefully), all seems OK here though circled in one pic is, what appears to be a piece of ally debris that needs investigation, I didn't notice anything while having a good look with the inspection torch so it may be one of those weird photographic things.
Pic 5 Sump rear of conrod:-
Pic 6 Sump front of conrod:-
Last pic Sump:-
Pic 1 piston rear:-
Pic 3 barrel rear:-
Last pic Sump:-
