- Wed Aug 08, 2012 8:31 pm
#960
I am restoring a 1958 Indian Trailblazer. The crankshaft plugs on this engine are the metal discs held in with a snap ring. How are these removed and reinstalled?
The con rods have the socket head capscrews cotter keyed at the threaded end. When I removed the capscrews the burrs on the threads, due to the drilling, disturbed the rod treads slightly. I marked the capscrews before removing them so I can return them to the same location and position after removing the burrs. Will I have to re-drill them after they are torqued? (They have already been drilled twice) Could a modern day "Loctite" be used instead of using the cotter keys?
