By enman
#83183
Hi I was recently told that when turning off engine if you stop it by the decompresser it will help save the sprag clutch as it will go over tdc, anyone got any thoughts?
#83188
Yes definitly use the decompressor. Kick backs are bad for Bullets, especially the Sprag. When you switch of with the ignition switch or kill switch you are switching off power to the coil. If the points are closed at the time, this could occur when the piston is a long way before TDC and the result will be to send the piston back the way it came.
#83189
