- Fri Nov 02, 2018 7:39 am
#8915
A while ago (forgot when) the suggestion was made to pull every connector apart and apply a thin layer of dielectric grease to shut out moisture and prevent corrosion.
Dielectric grease is non-conductive: the rationale seems to be that the connecting metal parts will push the grease aside so you achieve still good connectivity while sealing off against moisture etc.
Have you tried this and is the rationale okay?
Clement
Clement
