- Mon Aug 20, 2018 3:49 pm
#8748
I have pretty much all the parts I need to convert a drum brake 500 bullet to disc using an EFI wheel and a pricol calliper. I did have a different wheel and a brembo calliper but I still can't ID the wheel and the calliper doesn't fit with the EFI wheel (spoke angled differently and foul it).
Anyway, Got the wheel in and mudguards lined up so all I need is a bracket to fit the calliper to the fork. It's a simple cut-out bit of sheet steel however the hole positions are tricksy, two pairs of holes offset in 2 planes. I've asked our hosts if they can supply a bracket by itself but they can't. I've done an approximation based on my best guess but there could be a lot of bits of scrap steel with 4 slightly differently placed holes in in my scrap bin by the end of this process.
I wondered if anyone had one they would be prepared to draw round and post me the tracing so I can get the hole centres right? I'd be prepared to forward you some cash for your trouble.
