- Fri Jun 29, 2018 11:23 pm
#8609
Guys
I need some advise. I have a 59 Bighead Bullet that I bought after a "build" into a 612 with sports cams etc etc. It had not ever been run or wired etc. After redoing lots of the "build" - I got it running and bent the inlet pushrod. I then found it had been fitted with the standard valve springs and was suffering spring bind when running (it all seems fine when turning over cold - but I have measured the gap between spring coils when compressed and it is below spec. I have tried asking our host for more info and this morning got the part number of some springs that may help. I have asked what the difference in the competition springs are relative to the standard - but I can not get an answer. Can anybody advise ?
