- Tue Jun 19, 2018 12:04 pm
#8582
After experiencing a dragging clutch on my 1959 Airflow 350 I looked at the clutch release arm end of the gearbox mainshaft and found that the clutch pushrod was in good condition but not protruding far from the mainshaft and appeared to not have enough length for the operating arm to lift the clutch plates fully. No problem, I thought, must have forgotten to put in the 1/4" ball bearing when reassembling the clutch earlier this year, so pop one in now. The clutch now operates well and I cannot make it drag even by slipping the clutch mercilessly to try to provoke it. So what is the problem? The adjusting screw on the operating arm now fouls the circular cover plate, which suggests that the pushrod is now too long after putting in the ball bearing. Does anyone know what the coreect exact length should be for the pusrod, either with or without the ball bearing?
