By PO51UHD
#8543
Hello All
Went out for a VMCC Run today on Connie (‘59 Constellation with single Concentric carb). For various reasons I haven’t ridden her for 2 years, and I was really pleased with the way she was running, mainly on ‘B’ roads and below 50mph. On the way back, and getting closer to home I opened her up on an ‘A’ road. Got up to 60 no trouble, then she started stuttering and slowing, eventually stopping completely. After a couple of minutes and a good tickle on the carb, she started again and ran well for the last mile home. To me, it felt like I was running out of petrol even though I had a half tank full left.
I wonder if it was one of two causes:
• fuel tap too small (it takes ages to tickle when cold so I’ve suspected insufficient flow for a while). The tap is one of our Host’s cheapies and probably designed for a Bullet...
• insufficient venting through the filler cap (when I stop and put her on the stand I sometimes hear a hiss from that area)
Has anyone experienced this, and where to start on diagnosis and solution please?!
Thanks
Stephen
By Davedup
#77320
Wasn't just the carb getting too hot and the fuel evaporating was it?
Dave
By Valsp
#77321
Does the petrol tap have a built in filter? If so have you checked whether it is getting blocked by debris in the tank. It can get sucked up against the gauze when running hard and move away at lower speeds due to the fuel sloshing in the tank
By Jamesy
#77322
Have you cleaned the carb and checked the float function?.It has happened to me recently and the first thing I did was visually check petrol in the fuel line to the carb.it was ok.It hasn't reoccurred so I am hoping it's a one off.Carb. was cleaned and checked recently.
By Revband
#77326
"it takes ages to tickle when cold", a partial fuel blockage, possibly due to the cheap tap?, ethanol can expand the seals in the cheap taps and they block the flow.
Following up on Revband's point, I notice that our hosts list a big-bore 1/4" BSP fuel tap intended for methanol use. If the thing's methanol-resistant it should also be able to cope with ethanol in pump petrol.
Part No. PTAP2.
http://accessories.hitchcocksmotorcycle ... tank/16370
"• insufficient venting through the filler cap (when I stop and put her on the stand I sometimes hear a hiss from that area)"
That could be fuel vapour exiting the tank, particularly if you shake it up on a warm day, but you can still check the vent holes in case of partial blockage
#77330
Good point and well-spotted Adrian !!.......Back in the day when I was a "Methanol Jockey" on grass-tracking we used two taps on the fuel tank and Mk.1 Concentric fuel bowl to ensure max. fuel flow..........I can't remember the figures at the moment but as a rough guide Methanol mixes with air approx. twice as much as petrol does...........so you need to ensure a really good flow rate......I also think that "Hiss" might well be an indication that the fuel tank isn't venting properly...
By PO51UHD
#77346
Thanks for all those suggestions everyone. Methinks a Methanol tap and attention to the cap vent are on the horizon!
Stephen
By PO51UHD
#77403
Update: I checked the flow-rate of the existing tap. It took 2hrs 20mins to drain 5litres from the tank. Doing simple maths based on assumed mpg, it’s no wonder I experienced fuel starvation when I gave her some beans. I’m quite surprised she didn’t falter under gentle running!
High-flow tap is winging its way to me from our hosts as we speak!
Stephen
By ogri
#77468
Hi Stephen, I poster a near identical query (with the same title) just a couple of weeks back. Interesting you are going for the hi-flo tap and hope this will resolve the problem. Please can you let me know. Cheers.
