By Jamesy
#8522
After a ride there is a squeal coming from the back wheel of my b350.Its only after a ride and disappears when it's cold.I have just replaced the wheel bearings convinced it was them.I stripped it down and can't see the obvious and am not convinced it's the hub bearing.Anyone had this?
By Exile
#77059
Never experienced that. Could it be a brake liner? Lack of lube?
By Jamesy
#77060
The drum/ shoe plate on the left is showing rubbing wear against the sprocket assy on the right.When I tighten up the nut on the drum plate it is solid against the sprocket.The bearing/set up in the 38t sprocket looks nothing like the hosts parts manual.
By Jamesy
#77061
When I say solid against the sprocket I meant the sprocket doesn't turn freely
By vince
#77062
Hi, do you have the spacer 141115 which fits between the bearing and brake plate? Vince
By Jamesy
#77065
Spot on Vince it's missing and have ordered one.The distance collar item 12 part 141130 Is that on the inside of the rear brake plate.The parts diagram looks like it's on the outside.
By vince
#77069
Hi, despite the drawing it fits between the bearing and the brakeplate, the oilseal fits around it. Vince
