- Thu May 10, 2018 10:38 am
#8437
Hi all,
I've had a backfire problem with my 2000 Bullet 500 for a while that I'm getting increasingly anxious about. It only happens in the low revs range, mostly as/just after I downshift. In addition, recently I noticed the bike feeling like it's about to stall when going up a gentle incline at low revs. I also think I can hear a sort of light clanking sound coming from the engine - possibly the piston is hitting the cylinder head due to poor ignition timing? - but I haven't had the bike long enough to know if it's normal. It's not too loud, but audible over the engine noise.
I've changed the spark plug but I haven't adjusted the gap as it's the resistor version and my manual only has gap recommendations for the non-resistor version. I don't think it's a spark plug problem though, but what do I know?
Anyone know a way of diagnosing this? Assuming it's timing, any idea which way I need to rotate the timing plate (or whatever it's called), or how I might find out? Or might I need to fiddle with the carb? I have a mikcarb - will I need to get new jets and if so how do I know which ones?
Thanks in advance - it's hard to enjoy the ride when I'm thinking about the damage to my precious exhaust or any damage it's doing to the cylinder!
Geraint
Geraint
