- Wed Apr 11, 2018 1:03 pm
#8290
Hi all,
I have two questions about a 2000 Bullet 500, one regarding ignition timing and one about diagnosing a problem involving backfire.
So, question the first: I've been trying to set the ignition timing using the TDC tool from Hitchcock's. I insert the tool, put the bike in 4th and rotate the wheel through the compression stroke with the ignition on and hear the points separate at what I estimate to be about 1.5 mm before TDC. So I'm trying to get the piston to 0.8 mm before TDC as specified but I just can't get it to that accuracy. The stroke seems to be stiffer in some parts than others, and when I get to within about 1.5 mm from TDC it always seems to jump right to TDC or even through it to at least 1 mm beyond. It just seems impossible to get an accuracy down to a tenth of a millimetre. I've tried doing it with the decompression lever on. The way I'm doing it is holding the spokes and nudging the wheel forward a bit at a time. How is this possible?
Question the second is regarding some recent engine trouble. It seems to have occurred fairly rapidly after changing the oil but I'm not sure if it's at all related - changed it from whatever was in it when I bought it to Halford's 20w50 classic motor oil, and it was in need of a change. What's happening is that there's a lot of backfire in low revs - particularly when coming off the throttle to change down or up a gear. I think I can hear a light metallic tapping noise from the engine which is why I thought it may be an ignition timing problem but I haven't had the bike long enough to know whether that's just a normal engine noise I occasionally, much more rarely, get a misfire too. I inspected the points and they don't seem to worn. How can I tell if there's an incorrect knocking noise from the engine - what sort of volume would it be relative to idle?
Thanks in advance! G
