- Sat Mar 31, 2018 5:56 pm
#75374
I really wouldn't try to 'enhance' the numbers. You will need the correct font, not easy to find, and if you muck it up it will just arouse suspicion if an inspection is needed during the re-registration process. If the bike is already registered I wouldn't worry too much, my MOT tester (at least) is happy if the number is more or less legible on the first occasion and after that he doesn't check. Maybe I'm lucky! If you do need to re-register just tape over the number when the metal is bare before paint and leave it exposed, a quick blow over with an aerosol after inspection will be protection enough. The 250s always have very faint numbers compared to the Twins and Bullets, this is because the headstock is fabricated from steel tube and is much harder than the maleable cast iron headstock lug on the bigger frames which is pretty soft. By the way, this is the approach I intend to take with my next build which is a 350 New Bullet, basically a 350 Crusader.
