- Fri Mar 16, 2018 2:03 pm
#8181
This may be a magneto or carb problem, don't know; I'm usually pretty good with carbs (especially concentrics) but long story short a 28mm amal concentric (premiere) was fitted (because I had one & it matched the intake manifold choke size) to replace the very clapped out pair of mismatched mponoblocs originally fitted to the bike by previous owner. I set it up with a 230 main jet, 4 slide, needle pos 2 (mid), no air filter fitted (no room) but a wire strainer/gauze on the end of the short bellmouth. Magneto is K2f with manual advance; valve clearances were set at .002" inlet .004" exh (I know the book says nil).
Symptoms: sometimes when accelerating hard, and I do mean hard, the carb will spit audibly once, if I ease off the throttle immediately, the bike seems to recover - sometimes. However sometimes when accelerating hard the carb will spit & die, the engine refuses to restart. It has happened a few times, most recently this morning (when testing brakes - thankfully I only had to push the bike home on my home road, unlike yesterday).
I've always considered a "spit" a sign of weakness in carbs so I adjusted the needle richer - same thing, accelerated hard, then a spit, engine dead, wont restart.
On all occasions: after a while (say after pushing the bike home or smoking myself to death)the bike will start.
FWIW the position of the advance/retard lever, well, its so finicky, some days its an absolute pain to start.
I'm on the verge of throwing a hammer at the thing;( its driving me nuts
Mag? Ign timing? Carb?
