- Wed Feb 21, 2018 6:50 pm
#8104
Hi all
Following my fairly well documented rebuild I am having no end of bother getting the bike to run for more than a minute or so... I'm fairly convinced that it is a Carburation problem... Carb is a mk1 900 series concentric with 220 main and 106 needle jet..Carb has standard nylon float at the moment so not adjustable and the needle jet is working fine. I've thoroughly checked and cleaned the carb and blown through all fuel ways.. Are there any other checks I can do to ensure the carb is ok
