#74102
There should be a number stamped into the top face of the box, what is it? The others are casting numbers and not much help. It looks heavier than a Clipper type but the numbers should identify it.
By enfield_trials
#74183
Thanks Mark for your reply .. i think i need to do bit of cleaning to see the number.
i will check it out .. regards
By Marko
#74355
Hi, it looks like a "pre-unit" gearbox from a 250cc Clipper (1954-1958) or an Indian badged model... at 1st I thought it was Model G, J -ish (as on my bike) but then noticed the way the clutch is operated on your gearbox which is entirely different to boxes on other bikes with a "separate" box. Hopefully someone can confirm/dispel my thoughts?
