Hi Mark, you could try it - it certainly won't take long to do and won't cause any mechanical harm. On a machine which runs well, perhaps pulling hard from very low rpm through the mid range, but runs out of 'puff' at the top end, i would say give it a try. It may not be what you want for a trials type machine, although the firing pulses would be softer at low / medium engine speeds. Basically, you will lose a little at the lower rpm scale [not much] and gain more than you lose up at the higher end of the rpm scale. The 500 [Indian] Bullets respond well to this in fairly standard form, the 350's also rev more freely and will go faster overall with the change, but don't have the engine size to cope as well as the 500 with the slight loss lower down the rev range - raising the compression ratio on the 350 helps counter this. I tried a late valve timing on a pre war AJS 250 and this sounded the buisiness until I put it in gear and went for a test ride - the engine just didn't have the 'cubes' to cope and it became slower overall, in spite of revving higher in the lower gears, it couldn't quite catch the power band in top gear. Another thing a retarded inlet timing will help with is pinking in high compression engines - the reduced cylinder pressure when the piston is coming up on the compression stroke helps here, all due to the inlet valve shutting later, the engine will be easier to kick start and any electric starter would get an easier life. I think the Indian bikes have an early inlet timing because they seem to like to slog their machines and feel the 'thump' [not good for bottom end life] and it would seem their roads are pretty rough and crowded, so it might make sense to tune them that way. I have comparison videos of my own tuned 350 Indian Bullet and a couple of 500's, as well as that AJS 250 with before and after runs, also a tuned Electra X with Redditch 'S' cams running the inlet retarded by 1 tooth - might be of interest? All sorts of stuff here. Regards, Paul. ...
https://www.youtube.com/channel/UCcxcOW ... RWg/videos
