- Thu Nov 02, 2017 7:41 am
#7835
Hi all does any body know if this is normal. The motorcycle started to make a noise today. I took the timing case off and found a loose cam spindle. This is an older Indian motor that still has the pressure relief valve at the front of the motor near the oil pipe to engine flange. This cam spindle looks like it was held in the engine case using lead. It has been put around the base of the spindle to hold it in place. Is this normal practice or is it another Indian bodge. I was able to pull the spindle out just with my fingers. The lead may be solder but it is lead.
