By enfield_trials
#7767
Hi Guys
I want to take my 1957 clipper frame to local lathe shop to fit bullet engine.
i am thinking of bringing bullet engine crankcases and front mounting plate.
what else should i look for , i dont spare gearbox cases ,
do only the think any other modifications are required to fit bullet engine.
Thanks & Regards
ET
#71336
ET, are you sure the Bullet engine will fit? I seem to remember someone tried this and there wasn't enough room. It should be simple enough to do a dry run with engine and frame.
By papasmurf
#71337
I would suggest before contemplating fitting an engine you need to get the project to the stage of it being a rolling chassis, as in both wheels fitted, and aligned, so where the engine has to be placed can be determined accurately.
By enfield_trials
#71356
Thanks for your suggestions and ideas
i have checked one other forum last year, one of guy actually done similar conversion
http://www.trialscentral.com/forums/top ... d-project/
Hitchcock 1960 Bullet frame looks quite like mine .. not sure about measurement though
http://www.hitchcocksmotorcycles.com/pi ... ED2460.jpg
the clipper frame seems lighter to me and i have invested lot of time collecting parts etc
i hope it goes well
Regards
ET
#71358
The guy in the Trials Central thread did not actually say he'd done a Bullet into a Clipper frame, he said he'd "done that conversion" which isn't quite the same thing. It might be fine but you really should do a dry run first. And don't believe everything you read on message boards :)
The Clipper frame LOOKS similar to the '54/55 Bullet frame except for that cast lug on the bottom of the front down tube, which I think is where the problem will be as the holes won't line up with the mounting bolt holes in the Bullet front engine mounting plates. Assuming (not safe, I know!) the dimensions are basically the same you might just get away with a set of modified Bullet front engine plates drilled to accept the clipper front mounting bolts, but I'm not holding my breath.
By Tim NZ
#71375
Why are you wanting to do it? A lot of work for little benefit in my opinion. Especially if you are going to pay someone else to experiment on your behalf.
