- Sat Oct 07, 2017 5:56 pm
#7761
Does anyone have any tips as to easy main bearing insertion into late Redditch bullet cases? I froze the bearings and heated the cases in the oven. In the drive side I dropped in the small outer washer, then the seal, then the large washer, so far so good. The outer ball bearing was then taken out of the freezer and I expected it to drop in with minimal pressure. It was in fact very tight and I had to hammer it home with a drift on the outer race. It was slow going with the bearing sinking in only millimetres with lots of taps. It finally got down to beneath the circling groove but I felt very uneasy and felt like I might crack the housing. I've left the inner roller for now as my circlip pliers aren't big enough for the circlip. Am I not getting the cases hot enough? Should the bearings press in easily? Suggestions welcome...Chris.
