- Sun Jun 11, 2017 2:04 pm
#7399
Hi all, perhaps you can help with a very curious incident. On my 2015 B5 bullet I replaced the existing log with our hosts 91130 exhaust system (compatible with existing ECU). A lovely thing, works wonders though did take a bit of fettling to get it to fit properly. Now, it comes supplied with two exhaust gaskets to cover different depths of the exhaust port. I found I needed both for a good tight fit. I carefully attach said exhaust, check for leaks, none, so off I ride. All works well, but I start to get the occasional pop on the overrun. Bit loose I think, so I tighten the exhaust a little. Starts to pop a little again, so I tighten again, though no evidence of any escaping exhaust around the junction between pipe and head. All ok, then it starts to pop again, so I tighten. This is getting silly thinks I, these nuts are loose, I know everything shakes loose on a bullet, but this is just too silly. So I strip down the exhaust intending to silicon-seal the gasket to pipe junction and thread-lock the nuts, and find NO GASKETS. Just a trace of grey dust. Where have they gone? Do they burn? Have they been abducted? Did I forget to put them in? Two new ones are or order, but I know I shall stay awake at night wondering what happened to the last ones.
