- Sun May 14, 2017 7:10 pm
#7331
I started a new thread as a spin off from my query on sprocket bearings, as it's about the wheel bearings on Enfields.
So, as i mentioned in the other thread We found the bearing on the outer side of the rear wheel was not a tight fit in its recess and so the bearing was just slopping around basically useless. So a replacement wheel was obtained from our hosts from their special offer stock (many thanks to the helpful attitude and service at Mr h's spares counter). Today I had time to fit the new bearings in the new wheel as they come minus bearings. And I discover the same issue with the nearside wheel bearing, The bearing simply "drops" into the hole with no force at all required to press it in. I suspect there's a bit too much play to risk bearing lock compound to keep it from moving in its seat. Now 2 wheels with this fault may be a coincidence but I was wondering how common this is? I did a bit of back searching on this forum and found a couple of posts referring to slack wheel bearings and one advice to try using "Liquid steel" which I assume is the same sort of stuff as the "Chemical metal" epoxy based repair compound that has metal powder mixed in the resin. Assuming that this will work, would I be able to drive the bearing out again in the future if it needed replacing? I'm minded to try it with the old wheel on the basis of nothing to lose. I'll be on the phone to our hosts sharpish tomorrow about the new wheel but if this is a common fault then I am sure others would like to know how to tackle it. Of course a good machinist could probably turn up a sleeve to repair the oversize recess and bore out the existing hole carefully as there ain't a lot of metal there to play with. But the rest of us "mortals" haven't the skills or equipment to do this.
I actually like riding the 500 EFI B5, it is very comfortable and I can see how as a solo it could munch the miles at a nice steady 55 to 60 mph with the less restricting silencer and maybe a 18T engine sprocket to drop the revs out of the "tingle" band. But How much work does it need to make it decently reliable within its performance envelope?
Andy.
Andy.
