#7289
In need of help, I changed my 5.75 inch headlight to a 7 inch headlight and that's when all the problems started. The bike is a 2016 royal enfield efi 500 bullet standard. The 7 inch headlight has a bigger back end and started pushing against all the wiring and speedo cable which pushed it so that it rounded off and now the speed dial doesn't run, only odometer. I switched back to the 5.75 inch to avoid further problems and just left the bike alone. I go to start it around 4 days later and find that the neutral switch isn't glowing, horn isn't blowing, brake light not working and indicator's aren't working. I held the clutch in and self started it and it ran just fine. The headlight seems to work just fine but I don't know what to do about the other stuff. The fuse looked fine to me in the fuse box. Don't know what to do, any help would be very nice. Also a work around for the speedo cable would work but other electricals are a priority. Thanks.
