By enfield_trials
#7273
Hi Gurus
I have RE Model G forks. which i am planning to rebuild forks for trials project.
the forks are bit pitted as you can see .. i dont want to spend money on chrome if possible.
do you think they will bleed , what if i just the smooth surface emery paper. please advise
#67257
They probably will leak a bit but how much?
If this is going to be a trials machine then it will do minimal mileage and the leak may be acceptable.
#67259
Hi, I think you mean will the forks leak oil if the stanchions are too rusty or worn where they pass the oil seals which are screwed on to the fork lowers (sliders). From your photos I can't see the part of the stanchion that passes through the oil seal so I cannot make a guess. You need to drop the stanchions out of the yokes and post a picture of the area I have described. The upper part which I can see doesn't look too bad which is a good sign.
By enfield_trials
#67282
Thanks PeteF & Mark M for your feedback.
Yes i was asking about oil leaks. I am bit confused my friend have offered me crusader forks.
but i like Prototype RE trials i think there were only 10 made in 1948 , i like the period looking style of handlebar etc
https://youtu.be/i3dzCtnBzHY
Regards
