- Fri Mar 17, 2017 2:16 pm
#7160
Lots of you will have fitted Bullet engines so I wondered if they was a right and wrong order to refitting one. One concern is the lower and upper engine plates that are Fiddly when loose? Should all the plates be bolted up to the engine first before the frame? Would it be best to fit the 2 gearbox top triangles and the front down tube connections firstly then the lower engine plates? The problem is the stand mounts to them too doesn't it so is it best to fit these first maybe using a trolley jack under the Lump? It's a heavy lump so just thought I,d ask for your views before starting Asbo 21! Harvey
