By Ginge
#6890
As a newby to enfields, could any one explain the difference between C5 bullet and an E5/G5. Many thanks in advance
#64120
Mostly styling. The engines and frames are basically the same.
By Presto
#64122
C5 Classic Efi has completely different frame from E5 Electra Efi; C5 has single seat [not dual seat], tank side decals are completely different, mudguards are painted [not chrome], side panels and toolboxes are entirely different, C5 has fork shrouds [not gaiters], and different rear light assy. In fact altho engines are similar everything else is quite different between these two Efi models.
By Jack the Lad
#64162
Although rear wheel on an Electra (E5 or G5) is 19 inch and 18 inch on a C5, the gearing is not significantly different as they have one tooth less on the drive sprocket to compensate. Electra forks are different, with a neater design that does away with the mudguard stays. Otherwise as above.
