By papasmurf
#64100
I can think of many situations where it would be worth trying to adapt a rawlbolt as a puller in a situation where a bearing is "blind" at the back unless a major strip down is carried out.
#64106
Done this and I works well BUT not if you want to re-use the bearing.
By scotty
#64142
Think the spacer tube between bearings has slots in both sides you can fit a long skinny punch at an angle and drive bearing out then knock the otherside out with a socket and medium extension bar, at $8 each for 6203 bearings sealed why would you risk reuseing the old ones.
