By DaveP150
#6565
Hi All
I'm working on a Model G (well a few boxes of parts that should one day ressemble one again), and I was hoping that somebody might be able to help me with some frame dimensions.
It has a 1949 frame, but I suspect it may not be 100% straight.
Does anyone have the dimension across the bottom of the frame, between the centrelines of the front and rear engine lugs, or able to measure them for me?
many thanks
Dave
By DaveP150
#61022
thinking about it the diagonal measurement from the bottom front lug to the upper rear lug, (i.e. the points where the rear frames attach) would be really useful
cheers
Dave
By BrianG
#61046
I have a 1947 J which I think should be identical to your 49 G and the measurement centre to centre between the studs that the parts book online lists as #3 and #6 is 583mm. Hope this helps. Cheers, Brian
By DaveP150
#61049
Hi Brian
Thank you very much for measuring that. Interestingly my frame measures 600mm between the centres of those studs. Maybe different frames between J and G or just production variance?
many thanks
Dave
By BrianG
#61054
Hi Dave, You are correct. I checked my original parts book and all 3 frame portion part numbers are different to the G. Sorry about that. Hopefully someone else can help. Cheers, Brian
