- Thu Mar 31, 2016 10:03 am
#6095
Hi guys. I’m about to start work on my recently-puchased 1951 G2 - REOC having just advised it was a 1951 model not the 1953 model as it had been sold to me. Apparently it was originally sent to Shimwells of Birmingham who traded also in South Africa – so I guess they exported it out here (maybe it was only first bought here in 1953, who knows). It reportedly spent some years in Namibia but I can demonstrate its history only over the past ~10 years.
The bike starts and runs OK but there are a few parts that don’t look standard and I’d like to replace/fix.
1. I need a new speedometer (it has a modern RE one) – should that be 80mph? I have one of Mr H’s “chronometrics†on my 1996 535cc which looks the part and works OK. So one of them will do.
2. The gearbox has the clutch cable connection inside the box just like the 1956 G2’s – is that correct or should it be an outside connection?
3. The gearbox was oil filled and presumably has no sealed bearings – so I’ll change them.
I’m not sure if the silencer should be upswept as in the 1949 images or horizontal as in the 1956 images I’ve seen.
4. I believe it should have an Altette horn but at ~GBP90 that’s not happening, especially at GBP1=R22 (when it was R11 just a year ago!).
Anything else? Attached are a couple of photo’s (if I’ve got the transfer wrong, then they are available in my photobucket folder, Chrisd200).
Any comments welcome.
Cheers, ChrisD
Cheers, ChrisD
