By PO51UHD
#6046
Hi Chaps
Regular readers will remember my setup: 350 Superstar, BW glasflowed head, now with 28mm Mikcarb, S&B, more open exhaust.
The engine now runs ok-ish, but I'm going to experiment with jets.
Has anyone done this before (28mm on 350) and if so what Jets would you recommend?
Thanks, Stephen
By Bullet Whisperer
#56229
I don't know for sure, but I would assume the same settings for this carb type on a 500 with free flowing exhaust and air filter should be about right. Regards, Paul.
By PO51UHD
#56234
Thanks Paul, I will give that a try for starters - certainly the pilot seems a bit weak on std 500 jet so makes sense!
Regards, Stephen
