- Wed Feb 24, 2016 9:58 pm
#5963
Before I laid the bike up for the winter, I found I had a broken foot control ratchet spring - the figure-of-eight one. I replaced it, taking great care to re-fit the stop plate correctly. But I found that the gear lever doesn't always return to the central position after a gear-change. I re-checked everything but couldn't see anything amiss. Now I'm checking the bike over and plan to remove the end-cover for another look. Is there anything that you could suggest that I should be checking or looking out for as a possible cause of the problem? I'd be grateful for any advice. Apart from occasional clutch adjustments, I've never had any trouble with the gearbox in around 25,000 miles, so I don't know my way around the insides too well!
