- Fri Jan 08, 2016 6:02 pm
#5837
After beating the Royal Enfield around the local tracks for about 40 years I decided to clean it up and after a letter to Graham Scarth I found it to be a 1961 500 Fury in a 1957 700Indian Trailblazer frame. The bike has a rear sprocket that bolts to the hub instead of it being one piece, a Mikuni carb and the rear of the frame seems different than pictures. Can anyone tell me if the Indian frame is the same as Enfields, if they've seen a sprocket and carb like this before, why someone would combine this motor and frame, could this have been a crate motor, how many were made, does a Lucas N1 magnetic mean it was never street legal, and is it worth putting about $1,000 to make it pretty again being as it will still just be ridden around local fields and tracks? It is still great mechanically just needs cosmetics. Also what fluids are recommended for clutch, tranny, oil and front forks?
