- Thu Nov 26, 2015 1:23 pm
#52819
As I understand it from my mot guy, a front mudguard is not required, also although a speedo has to be fitted, it doesn't have to work. There are all sorts of other funny little quirks like this, too. I am not a fan of 'bobber' type machines, but have been involved in some to varying degrees at the request of others. Recently, while test riding one with a huge potential for performance from the engine, I found myself immersed in thoughts regarding the total lack of ground clearance - the prop stand is not required, it will lean on a footrest - and having to slow down to a snail's pace to get round average corners. speed bumps were another hazard and negotiating a roundabout had me slipping the clutch in 1st gear. The lack of a front mudguard, and to all intents and purposes a rear one had me soaked through in minutes, the spray off a wet road went up my back, then ran down inside my leggings, while there was so much water flung up from the front that I might as well have been sat in the shower and it would have been no worse and it wasn't even raining, just a wet road surface. No rear view mirrors added a little more to concentrate on / worry about. Each to their own, but these things are not my cup of tea. Cheers, Paul.
