By Thunderdird 2
#5649
Just got the 2006 Electra on the road today after being delivered.
Bike goes very nicely, but I seem to have a 'clattery' noise, not tappets, noy heavy enough for ends, but was wondering if it could be the PAV valve as mine is still fitted, its not like I had on my old Bullet but comes directly out of the head.
Do these make a noise?
Just checked the tappets and even though the engine is still hot they seem loose, one spins easily the other turns with a bit of pressure, as I would set it from cold, cant do anything until the engine is cold so job for tomorrow.
Cheers
Terry
By Tim NZ
#51954
Yes,the PAV can be quite noisey at times. Check that the wee 'trigger' hose is not damaged loose or leaking?
#51955
If your tappets are at all tight when hot they will be over tight when cold.
By Thunderdird 2
#51956
Thanks chaps, I will be checking the tappets today, also removing the windscreen as this can reflect and amplify engine noise, I've had this before.
Terry
By Thunderdird 2
#51959
During a hole in the rain I checked the tappets, exhaust could not be moved at all, inlet just about moveable, now set correctly it sounds a lot better, just run it to hot, nowhere near as noisy or rattley.
Looking forward to road testing, but pretty sure it will be a lot better.
Terry
