- Sat Sep 05, 2015 7:18 am
#5494
Does anybody know if the T3GP2 Amal 1'1/2' carburettor can be converted to run on Methonal/Ethonal , Here in Australia you can buy E85 fuel at the pump , thats 85% Ethonal 15% petrol . I bought the Amal Mk2 Concentric 32mm for my ported almost full race 1995 Indian made engine ( now 612cc ) , apart from having to raise the rear end of the fuel tank to give the throttle cable room..... but I am thinking about converting the bike to a Fury replica and with the big head comes a few problems , can the T3GP2 be converted ? No Methonal parts are listed so can the parts off a 38 mm Amal smooth bore be fitted to the T3GP2 ? If not I will have to fit a MK 2 smooth bore and with the special 38 mm flange adaptor the carb will be in a possition where the cable might clash with the Fury fuel tank or might even put the cable in a possition where it is not even under the tank but outside the tank recess and will mean a Velocette Thruxton cutaway will have to be made to the tank and that will add to the cost of the conversion which I am trying to work out . The other thing is the angle of the semi down draft angle of the Fury head inlet port which might be too much for a MK 2 concentric to cope with .
