By Reg
#5464
G'd evenin' all, Just wondering if anyone has done away with the standard air filter by simply removing the rubber connecting tube from triangular housing/toolbox to tea caddy. Obviously the carb would need re-jetting. I thought this might have the same effect as fitting a bellmouth, but leave the electrics less on view.
By Exile
#50647
I had considered something like that myself a while ago but ended up fitting a conical air filter and found a cover for the electrics. All available from our hosts...
I blogged my progress.. you can read it following the links below:
Air filter
Electrics cover
Don't know if that's of any help, or even answered your question,but the resulting appearance of my efforts is pretty cool..
#50651
An alternative is to fit the circular S&B filter that is a straight replacement for the original but with much less restriction.
They are a bit expensive but they are washable so should last.
