- Mon Aug 17, 2015 7:28 pm
#5427
My Pal has a 2008 500 Classic iron barrel.
He recently rebuilt the bottom end on account of main bearing failure.
At the same time he fitted a Boyer Branson ignition system (I know, he should have done one thing at a time but the A/R was knackered and it's almost as cheap to fit the BB)
Anyway, the engine will start cold and will restart hot (even if it's not running particularly sweetly) Trouble is, if you leave it for 15 minutes it refuses to start until stone cold again.
I'm fairly sure we have the timing more or less right and the carburation can't be far out either as it starts OK from cold (or hot as long as you don't wait around)
I know nothing about BB systems - can anyone shed any light?
Our next move is to strip and clean the carb (again) unless anyone has a better idea.
It has a Monobloc fitted but that was on and OK before the rebuild. It also seems to need a bit of throttle to start from cold and looks like it's running a touch rich but by no means sooty.
Classic C5 Euro 4 at the moment.
Also CBf250.
Also CBf250.
