By dan1612
#5399
Now I am onto the hex bolts at the top of the forks and these too don't want to budge - anyone had similar? I'm leaving over night with some penetrating spray and will give another go tomorrow but I suppose heat will be the answer??? For my sanity though, I can't find anything in the manuals to disagree, the thread is a standard anti-clockwise to undo? Correct?
thanks once again
#50120
Are you talking about the 1/2 inch hex socket in the top of the fork leg that screws into the top yolk? They are rht but as you are working from the "bottom" of the thread you need to unscrew them clockwise. Just needs thinking about - you wouldn't be the first to get this wrong.
By dan1612
#50122
yep just had the light bulb moment and realised the same. However does this unscrew a bolt holding the upper fork into the cassette or the entire fork?
thanks
#50124
You are unscrewing the fork tube from the top yolk. The top of the tube is threaded and the hex socket is formed in the tube itself.
#50126
To clarify, the top yolk is the caskette on these machines.
By Ian Martin
#50127
If you can't find a hex key big enough in your everyday toolkit the front footrests stud fits the top of the fork stanchion. I've used this method to remove mine.
Ian
Shouldn't that be top yoke? The yolk is what I always manage to overcook when doing soft-boiled eggs! A.
#50136
You're right of course Adrian, blame the red wine 😊
By dan1612
#50145
Thanks all, will give it a go tonight - it's the last part of the dismantling. Rebuild is next.....
