By Scalyback
#50429
[center]
Ted,
On youtube, select 'share' and then 'embed'. Copy the code from there.
That has a couple of **odd** side effects, the illusion (I hope) of the bent rear shock absorber, and the stranger illusion of the rear hub appearing to stand still, run forwards or run backwards regardless of what the rear tyre's doing. I guess this must be due to the frame rate of the camera coming in and out of synch with the rpm of the back wheel. Nice steady picture, though.
