- Sun Jul 05, 2015 12:32 pm
#48900
Thack,
As long as you use the same type of speedo to get the MPH it should be fine.
Check that the zero's line up and that the 50MPH lines up with the 80KPH (Well, almost exactly), same with 75MPH and 120 KPH and also 100MPH and 161 KPH. That will be close enough. Easy if you can print on thin paper first and overlay on speedo to check.
50 MPH = 80.47 KPH
75 MPH = 120.7 KPH
100 MPH = 160.93 KPH
Add the RE logo, or the bike's name as well maybe?
REOC 15084
Tabellarius de verbis. Ostensor gaudium
