- Tue Jun 09, 2015 7:47 pm
#5158
I've noticed that my bike get rather buzzy above 4250rpm, but I'm planning on adding the hotter cams and valves to the engine to compliment the open pipe, filter, and PCV I've already fitted. I'm a little worried about using that power, since it's made at and above 5,000rpm. Having had a piston fail and let go of the piston pin previously on another bike, do you think the stock piston and rod will happily handle the increase in rpm and hence increased forces? Also, is the vibration a sign that the stock piston weight is too much for those higher rpm? Are there any options for a lighter 535 piston?
Thanks for your advice,
Gavin.
Gavin.
