- Sun May 31, 2015 8:26 am
#5130
I've now got my 2004 Bullet 'Sixty 5' back on the road after a good strip and clean. It started on the first kick after 14 months laid up. Once fully warmed up it rides beautifully. It starts best with the Micarb enrichener lever down and immediately returning it to the up position as soon as it starts, otherwise the motor coughs and splutters because it's too rich. However, it still needs a hand on the throttle to keep a fast tickover or it will stall.If I ride off too soon the first mile or so are a bit lumpy until it fully warms up. It really needs some halfway choke position while it warms up (and while I finish getting togged up). I get around it by adjusting the idle screw to a fast tickover but that is very fiddly because of the battery being in the way. It then needs to be turned back after a few miles, as well.I guess that is the advantage of an Amal carb with a proper choke controlled by cable and lever.I was considering of attaching some sort of flexible pipe/cable affair to the idle screw to make it easier to adjust during the warm up period. Anyone have any tips about these initial warm-up minutes?
