- Sun May 03, 2015 8:28 pm
#5024
Hi all
I’m new to the forum, but this weekend’s events have led me to finally register.
I gave my 2012 EFI E5 Bullet Electra a 13,000km service this weekend. Amongst other things, this included replacing the fork oil for the first time. After checking the workshop manual and Pete Snidal’s CD, this seemed like a pretty routine task; remove the drain plugs at the bottom of each fork, allow the oil to drain out, undo the filler screw plugs in the headlight casket, refit the drain plugs, fill with fluid.
However..
Upon removing the drain plugs, barely a single drop of fork oil came out. I opened the filler plugs thinking a vacuum may be retaining the oil. Nope. Not a drop more came out. Had my forks been leaking? Not a chance. I’m the sole owner of the bike, it’s been parked in the same place practically every day and there’s never been any leakage of any type.
By now I was starting to wonder what was going on, to put it mildly.
Next step then. Fill some oil into the forks. I took off the chrome filler screws, measured out 250ml of oil, put a funnel in the hole and poured slowly. Result: Oil all over the show. What on earth? Not a drop of oil would pass through the funnel into the hole. After much mopping up and inspection of the hole it becomes clear that this hex-shaped hole is only about 3cm deep. The only thing to put in there is an Allen key – certainly not oil.
Next follows much frantic re-reading of manuals, google and youtube searching. The nearest I got to any clue was 5mins 35secs into this video for a G5 Electra (= an E5 with more chrome).
https://www.youtube.com/watch?v=eY8F-J0ej2Q
And I quote:
“Some never models do not have a filler hole under the top chrome screw plug.
Their forks must be taken off to change fork oil.
Their drain plug is also different.â€
How the video maker knew that, I don’t know. I was certainly grateful to him.
Thus ensued a full-frontal lobotomy involving taking off the wheel, removing the forks with above-mentioned Allen key and filling the oil from the bottom.
Now. I don’t mind doing a job – if I know what’s involved. I don’t blame Pete Snidal. I’m certainly not impressed by the totally misleading and plain wrong expensive official factory manual, however.
Far more seriously, my bike has done 13,000km without a drop of oil in the forks. I’m angry, dismayed and feeling relieved I’ve not had a critical failure and accident.
Please, if you own an E5 or G5 and you’ve never changed the fork oil, I would urge you to loosen the drain plug at the bottom of each fork and see if any fluid at all comes out. If not, you too could be running on a potentially lethal bone-dry front suspension. You might also like to remove the filler plugs in the casket to see if the hole is blocked off.
I’m going to contact the factory to see what they have to say about it and I’ll keep this forum informed of their reply. For me, shoddy doesn’t describe it. I’m going to ask them for new fork assemblies, as heaven knows what condition the springs are in.
Thanks for reading and wishing all safe riding.
Matt Rayner
However..
And I quote:
Matt Rayner
