- Mon Apr 27, 2015 1:12 pm
#47147
OK, Exile, I notice that you have a basic misunderstanding of what 'Ah' means. I know this because you wrote 12v/12ah (144 Watts), which doesn't make sense.
There is a difference between amps (A) and amp-hours (Ah). When we are talking about amps, you are correct that you can multiply the amps and the volts to get the watts (watts being a measure of the power being dissipated at an instant in time):
watts = amps x volts
amps = watts / volts
volts = watts / amps
For example, a 60 watt headlight bulb draws: 60W / 12V = 5A
However, none of this is relevant to what you want to know, which is about amp-hours (Ah). This refers to the electrical capacity of the battery, and it is easier to give you some examples.
Your battery is rated at 5 amp-hours (5Ah), which means it will supply 5 amps for 1 hour. If you draw only 2.5 amps, then it will last for 2 hours. If you draw 1 amp, it will last for 5 hours. If you draw 10 amps, it will last for 0.5 hours.
Hopefully you can see that if you multiply the current by the time, it always comes out to the number 5. I'm hoping this feels intuitive for you: if you take out twice as much current, it will only last half as long. Thus, if I had a 10 amp-hour battery, it would supply 10 amps for 1 hour, or 1 amp for 10 hours.(*) Of course, all these numbers assume you are starting with a fully charged battery.
Thus, you are partly right in thinking that a fully charged 6Ah battery will drive your GPS for a bit longer than a fully charged 5Ah battery, but that isn't important because your battery should not be driving the GPS. When your motorcycle is running, your battery "floats", neither providing nor drawing current (apart from a bit to charge it up). The electrical equipment should be powered by the alternator.
If your alternator isn't powerful enough to drive your GPS in addition to everything else (ignition, lights, etc), then - as you would imagine - the battery steps in to make up the difference for as long as it can before it goes flat. If this happens you have a problem with the alternator (or voltage regulator), because the alternator should easily have enough headroom to operate the GPS on top of everything else.
HOWEVER - are you SURE the GPS is closing down because of a low supply voltage? Something makes me think there is more going on. Is it programmed to shut down after a certain amount of time without the screen being touched? Are you SURE it is actually being powered by the bike's 12V supply, and not actually running on its internal battery?
I bet this is something to do with the GPS itself, and not the alternator, regulator or battery.
(*) The experts will know that I've slightly simplified the amp-hour explanation by not including hour rate (e.g. 5Ah at 10 hours), because it only leads to confusion at this stage.
