- Fri Apr 24, 2015 12:17 pm
#4959
Just been setting the ignition timing and points gap on my 2000 Classic 500 and needed to accurately find Top Dead Centre (TDC). I found this method on the web and decided to give it a go. After a bit of time taken in setting it up it proved to be an easy and extremely accurate way of finding TDC. I've now completed the work and my bike is running as sweet as a nut. Anyway here it is if anyone is interested........
1. Make an indicator from some clear plastic tubing, a jar of light oil, and an old spark plug.
2. Break up an old spark plug and attach a length of clear plastic tubing to it (make it airtight).
3. Remove all the spark plugs.
4. Stick your thumb OVER the #1 cylinder spark plug hole. Rotate the engine until you feel pressure on your thumb. That's the compression stroke. TDC is at the top of this stroke.
5. Screw in the spark plug with plastic tubing attached and insert the other end of the tube into a jar of light oil. Continue rotating the engine. Bubbles will appear until the piston reaches the top of its travel. When it starts down on the next stroke, the bubbles will stop and oil will begin traveling up the tube. Stop at a convenient point and mark the tube. Then mark the crank pulley and the engine body at a convenient spot.
6. Rotate the engine backwards and watch the oil recede into the jar. Continue rotating. As the piston continues past TDC and downward it will again suck oil into the tube. Rotate the engine till the oil again reaches the mark. STOP! Mark the crankshaft pulley where it lines up with the mark you made previously on the engine. You should now have two marks on the crankshaft pulley. The midpoint of these two marks lined up with the mark on the engine is TDC.
