By Phil Ashbrook
#4925
Please could anybody tell me if it's OK to fit the shims on both side of the sports cams , is there enough room rather the outer side rubbing on alloy ? Plus the timing side woodrough key seems too big and has to be filed down a bit or it would foul the pinion .
#46689
Phil, not sure why you would want to fit a shim on the inside, the cam runs up against the spindle, shim on the outside stops the cam running up against the timing cover
By Bobw
#46690
Hi Phil, I,m not sure why the key would need filing. The timing side of the long stroke crank should be exactly the same as the original. Perhaps a light rub on a wet stone but the key needs to be a good fit in the slot and may need a gentle tap to seat it. Best not to start filing until you understand the problem.
