- Mon Apr 13, 2015 9:01 am
#4897
Hi all I took my electra X out the other day and while it normally starts 2nd kick, I had somehow put the kil switch in the off possible so after about 4 kicks.it started smelling of fuel. I put the kill switch back to run and it started next kick. Once it had reached normal operating temperature it was misfiring on a constant throttle but ran ok under load. Once I got home after approximately 20 miles I removed the plug to find it black and sooty.I cleaned.the plug and tried it again and it still misfiŕes. This is the third it has had in 3k miles
I ran it without the plug cap on by holding the ht lead against the plug and.it has a good strong blue spark that will jump a 15mm gap without breaking down so that to me suggestions the coil etc are all good and the plug cap is new.
Does anyone know how to stop it eating plugs or have I just been unlucky?
