By stefaand
#4751
I've been digging into my engine, and I was looking for some opinions of the experts:
there is a coating of oily mud everywhere on the inside, it cleans off easily though.
#45195
Classic signs of piston blowby, probably caused by worn rings and bore. It also looks as if the oil hasn't been changed that regularly, and that's not unusual too!
By mauri
#45199
call the good man by his name, and he will come
all together now
father norm, father norm, …..
im no expert so will shut up, just passing for the pic’s.
By stefaand
#45203
Thank you. It only has 22000 miles on it, I hope it's just the rings and perhaps a hone rather then a piston and bore..I'll make an appointment with the honda guru for measurement. And with the triumph guru for a magdyno pinion extractor, before i destroy the poor thing.
By papasmurf
#45205
Given the amount of cag on the piston, it needs throwing away not cleaning, unless you wish to measure the piston to see how much it is worn, and or how oval it is.
