- Sun Mar 08, 2015 10:01 am
#4740
Firstly thanks to all who responded to/read my request for help with my Boyer. Think we have found the problem in that someone I also contacted had a similar problem a few years ago on his BSA. He did all the same tests and fault finding as myself (coil test ignition lead swops etc) and came to the conclusion that 1 ignition trigger had stopped working and by running the coils in parallel you could overcome it as both coils were being fired by the 1 impulse. He replaced the system and it's still working fine. I suspected the triggers but this has helped confirm.
Posted to help any others on the forum as electronic ignition has become more standard with owners I meet and trying to track faults is stressful shall we say. I will however stick to points for my 57 Bullet as its easier in my mind with far more tolerance of issues (e.g. battery down).
Trust you all enjoy the summer season.
Hugh
Hugh
