- Mon Feb 09, 2015 6:29 pm
#4651
After finally getting my cylinder head off I have taken off the barrel as well. There was a lot of soft carbon on the piston and in the combustion chamber which I have cleaned off. I`ve checked the end gap on the rings and they are well within tolerance. I`m wondering now whether I should change the guides while the head is off. This bike did use a bit of oil. Or do you think I could get away with just fitting some of the guide seals that Hitchcocks sell. I`m going to fit the larger exhaust valve while I`m at it as well.
